Old 09-30-2017, 01:36 PM   #12 (permalink)
gpfaster
Saturn - '01 Saturn SC1
90 day: 42.33 mpg (US)
Thanks for the feedback. Learned that today. Seeing the benefit of "dfco" when the vehicle speed is above 50ish km/h. Anything below that and I'm getting better numbers with the gearbox disengaged. From what I'm seeing on the app this car very rarely if ever shuts the injectors completely off. But my fuel numbers do drop "dfco" vs neutral coasting even with an indicated higher engine rpm so the injectors do throttle back. Fairly confident the app is working properly as i am seeing 0 liters consumed per 100k when using eoc. Still learning what is happening as I put time into the app. Need to stop beating myself up as I am getting pretty good mileage from this vehicle
