Old 10-02-2017, 08:22 PM   #135 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Chill plate on Paul Holme's controller
Putting together the chill plate on the bottom of the controller, with gasket .. goop? .. and then the bottom cover.
A short circulation test follows
I don't know the actual thickness of the aluminum between the IGBTs and the water channel. So it is difficult to speculate on the required flow rate of water to remove the heat from the controller.
I expect that this flow rate will do for any normal driving, at least.
2016 Sep 25 Mazda MX6 Day 819 video 47
https://youtu.be/CyPPG6MIdpA
Still a year behind in posting!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
Daox (10-03-2017), freebeard (10-02-2017)
