Old 10-04-2017, 12:01 AM   #61 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by mazdamx640 View Post
I'm interested in putting 12 hole injectors on my 99 f150 4.6 I know the stock is 19lb but not sure on body or electrical connector any idea on what might work?
I can't find very many 12 hole injectors at all, and cannot find anything that flows 19 lb/hr. Nearest I can figure, your injector cross-references to a Bosch 0280150955. That is an EV1 single pintle design with a Jetronic connector.
You may still get some improvement in FE by switching from your existing EV1 injectors to EV6 injectors that have 4 holes. I found injectors that will probably work, and they are p/n 0280155709. However, they apparently are only found in Europe.
The Following User Says Thank You to t vago For This Useful Post:
mazdamx640 (10-04-2017)
