Old 10-06-2017, 04:12 AM   #5 (permalink)
cRiPpLe_rOoStEr
The more air a blower moves the more power it draws so putting in a high flow filter or removing the filter will make it use more power.
Since there would be a lesser restriction to the air flow, it doesn't seem so likely to require more power to blow that greater air mass.
The only way it would use less power is if you put it on the high setting before and now you only turn it to the second highest setting with the high flow filter.
This sounded to be the case.
