Old 10-06-2017, 09:51 PM   #12 (permalink)
twj347
2015 WRX - '15 Subaru WRX
90 day: 30.63 mpg (US)
2008 Suzuki SV650SA - '08 Suzuki SV650SA
90 day: 60.81 mpg (US)
Originally Posted by oldtamiyaphile View Post
Most petrol cars will run open loop (rich) after a restart, which may be enough to counteract any gains from short P&G cycles.
Not sure about all cars, but my O2 sensor is warm enough to run closed loop within a few seconds of restart if my engine is hot. Also, closed loop does not necessarily mean rich. The ECU will still target an AFR of 14.7:1 at low loads, but may be a bit rich if the MAP or MAF scaling is off. There are also post-start enrichment tables. For my for my car, post-start enrichment only lasts for 5 seconds and injects 2% extra fuel during this period (with coolant temp over 80 degrees C.) The extra fuel will be really minimal, even with shorter P&G cycles.
