Old 10-07-2017, 12:24 PM   #94 (permalink)
oil pan 4
Originally Posted by Jack-Lee View Post
i bould a waterinjection for my diy engine. Compression 12,5:1 and afr about 16,2 at full throttle. I need the Water/Ethanol to cool down Pistons and Valves and to prevent knocking. It works. Without the WAES i only could drive with AFR 14 at full trottle AND take back the injection values -> roundabout 20% lesser efficency.
That is kind of sounds like what I have out in my garrage. An 8L 8cyl engine with 11:1 compression. I don't want to use premium gas forever. What I would like to do is run regular gas for cruising around, hooefully in lean burn, not using any water injection. Then when I open it up then add some water methanol injection.
