Old 10-08-2017, 07:28 PM   #2 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
What I would like to do is find an adhesive, rigid material that applies as a liquid. I could put it between two sheets of coroplast and suck them apart. If the material [easily] pulls apart as strings which then harden, that is what I would be looking for.
You might experiment with construction adhesive. Apply a bead with a caulking gun, stick the sheets together, and immediately pull apart. It's been a long time since I used any, but I think it will pull apart as strings up to at least a 1/8" gap, maybe a 1/4" gap. Don't know if it will work for what you want, but at least it's cheap.
