Old 01-15-2008, 06:26 PM   #18 (permalink)
newtonsfirstlaw
The Mighty Mira - '92 Mira
90 day: 61.32 mpg (US)
Originally Posted by WaxyChicken View Post
How will you change the tire with the skirt attached like that? it looks like one none-removable piece.
It only goes up half way, and if you've ever changed a tire, you'll notice that the tire drops down quite a ways when that end of the car is jacked up. In addition, the rubber is pretty flexible considering it doesn't have to bend very much to move outwards.
A professional version of this mod would use some sort of spandex the color of the car, and have a strip going around the outside that would anchor the material and be removable.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
