Tapping into the booster line will leak down your vacuum supply when you turn off the engine. I have mine tapped there right where the vacuum comes out of the engine, but I do not EOC and not worried about my connection.
Another place to splice into on a Metro is the line that goes to the MAP on the firewall. It has a "filter" on it. Does not interfere with the sensor either.
