Old 10-11-2017, 12:11 PM   #18 (permalink)
JockoT
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Originally Posted by elhigh View Post
JCP,
You can engine-off coast your Honda if you think it will be worth the risk, bearing in mind that if you turn the key a notch too far, you lock the steering. One click, not two.
My steering lock only works if the key is removed. I can turn the key two clicks, and provided I leave the key in the barrel I can turn the steering from lock to lock (not easy when the wheels are on the ground), and the lock will not engage.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
