Old 10-13-2017, 11:08 AM   #3 (permalink)
nickritter1992
Originally Posted by elhigh View Post
The taller tires will probably help. It would feel less than fabulous to get new tires so soon after having just fitted these, though.
Warm air intake is your way forward, not CAI. Cold air = more mass flow into the engine, = more fuel capacity = more power. Warm air means less mass flow, less fuel, less power, requiring wider throttle openings to maintain the same power. Lower pumping losses.
Fire up the Hondata monitoring and see what AFR it's giving you. Will it permit lean burn? Can it be tweaked to do that? With the second O2 sensor it may not, and I think some of your fuel economy potential went away with that second O2 sensor.
car needs to be converted to OBD1 then chipped with eprom then Wideband 02 would be 230$ for that mod if I tuned it at causing conditions just don't know if its worth it
tires are cheap If you factor in megs gained over the course of a year with 25k miles a year it will make up for its self
