Old 10-13-2017, 01:41 PM   #11 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
The problem with using an E85 capable van as an example of having a fleet that uses alternate fuel insinuates that you might actually fill them with E85. They don't. My guess is the electric trucks with the generator range extender will run those generators all day even if the battery alone would get them through the day. All It will take his one time out of the many times it happens when the day goes crazy long because of delivery volume and the trucks go dead and then the generator isn't enough to finish the route and get you home. Imagine some of those times where it's 15 degrees out with a foot of fresh snow in the black of night.
The Following User Says Thank You to Hersbird For This Useful Post:
wdb (10-14-2017)
