Old 10-13-2017, 11:48 PM   #310 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by oldtamiyaphile View Post
I also wonder what happens if you come at it with a pair of jumper leads
It will charge or discharge, depending on the voltage difference between the two batteries. Could be a lot of amps, depending. Not an issue, unless it's charging below freezing, or the cells are imbalanced and one of them gets driven over 3.65 volts. Discharging isn't a problem unless one or more cells gets driven below 2.7 volts.
