Old 10-16-2017, 08:09 PM   #48 (permalink)
Panther140
Panther140
Originally Posted by dwtaylorpdx View Post
FWIW ,, on another forum that specializes in the LS grandchildren engines from GM, the FIRST mod on the newer ones is to disable the Variable displacement system. Its been tagged with serious engine wear issues (Again... Remember Northstar?) The un-powered cylinders wear out rings too fast.. And have piston scuffing issues.. For about 800 bucks HPtuner would let you play all you wanted with how it runs..
For $800 I could just replace each of those pistons 3 or 4 times
The engine gets 20% better thermal efficiency when in V4 mode than it does in V8 mode doing the same amount of work.
2007 Silverado 1500 2wd flex fuel with active fuel management. 33" Nitto Terra Grappler tires. 2.5" motofab front end leveling kit.
