Old 10-18-2017, 07:23 PM   #14 (permalink)
Panther140
Panther140
Have you guys ever heard of the pulse-and-glide method of hypermiling? Accelerating up hills and coasting down them should be thought of the same as the pulse and glide method.
However, it is even more efficient than the standard pulse and glide method on flat ground. That is because it leverages potential energy. It allows you to use the pulse and glide method without as much wind drag.
2007 Silverado 1500 2wd flex fuel with active fuel management. 33" Nitto Terra Grappler tires. 2.5" motofab front end leveling kit.
The Following 2 Users Say Thank You to Panther140 For This Useful Post:
Ecky (10-18-2017), PaleMelanesian (12-04-2017)
