Old 10-27-2017, 02:32 AM   #8 (permalink)
JockoT
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
If your line of thinking had been valid I think the automotive industry would have adopted it a while back. What you have in an EV battery pack is already a collection of Lithium Ion CELLS, connected up to give the required voltage and capacity. A 375 volt EV battery is composed of multiple series sticks of 100 cells, connected in parallel, to give the required capacity. It is like a 12 volt lead acid battery, as used on most road vehicles. It is composed of six 2 volt lead acid CELLS connected in series.
To get 30 kWH of capacity from a Lithium Ion battery requires 8108 3.7 volt cells.
Kilo watt hour (kWh) to Ampere hour (Ah) Conversion | EverydayCalculation.com
So you would have 81 parallel sticks of 100 cells to achieve this. This is what the EV battery is composed of.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
