Old 08-22-2008, 01:59 PM   #13 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
My Mule - '04 Vibe
90 day: 41.02 mpg (US)
The Family Truckster - '06 4-Runner SR5 2WD V8
90 day: 20.45 mpg (US)
The Trailer Queen - '04 xB
Having the same car I too have put thought into the same idea. Here is what I have been contemplating;
-A dry Ice cooler, attached to the a/c recirc intake inside the car under the dash. This cooler would have an ambient temperature fan to keep it cool as long as possible, but it would draw the cooled air through the vent thus providing a/c for as long as the dry ice lasts. You would have to test to see how long that is, but it may work.
Second option;
Remove the compressor from the belt system, research the smallest compressor possible, like the motorcycle ones used on goldwings, etc and drive it with an electric motor. The draw from that could be offset with solar panels or a second battery off the system that you could charge nightly.
Try that see what sticks ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
