11-11-2017, 12:48 PM
Good point about unsprung mass.
I suppose the real answer to the question is: It Depends (TM)
- It depends on the difference in RR between the available tires;
- depends on the weight difference between the wheel/tire combination;
- depends on whether the driver will be using top gear enough that the effective gearing difference will be an issue
