Old 11-11-2017, 06:43 PM   #5 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
You'd need the 60 LB valve springs to support the higher RPM, but those are easy to do.
I've done governor spring kits many times on P-pumps. If we could find the parts to convert yours to a P-pump, it is a bit easier to make big power.
I even have a spare rebuilt 215 pump, already set for 3500 RPM on the springs.
The trouble is, different injectors, lines, and timing set. It is a big job.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
aerohead (11-18-2017)
