Old 11-16-2017, 04:46 PM   #3170 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by ScottyWarpNine View Post
That seems to have solved the connect problem. Still won't program though. I get this error message:
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x63ff
configuration memory
program memory
Address: 0 Expected Value: 40100 Received Value: 0
Failed to program device
2017-11-16 12:50:27 -0500 - Programming failed
Pass Count: 0
That looks familiar. Do you have the PICkit 3 plugged straight into the board or are you using an extender cable?
I ended up taking Paul's advice and using only a male - male pin header instead of the short parallel cable that came with the PICkit 3. Before I did that ... I think I was getting a similar error message.
I used the USB cable that came with the PICkit 3, running approximately 90 degrees to the other cables on the board - encoder, throttle, contactor signals. I don't know if that part helped or not.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
