Old 11-17-2017, 07:56 PM   #310 (permalink)
Daox
Well, I decided to roll the dice. I resurfaced the flywheel and pressure plate by hand tonight with 80 grit sandpaper. We'll see how it turns out!
The tool and the finished pressure plate:
Here is the finished surface. As you can see, I didn't dig into the metal much at all. The main purpose was mainly to remove any clutch material from the surface.
Flywheel before:
Flywheel after:
ID:	22956   Click image for larger version
ID:	22957   Click image for larger version
ID:	22958   Click image for larger version
ID:	22959   Click image for larger version
The Following User Says Thank You to Daox For This Useful Post:
California98Civic (11-18-2017)
