Old 11-18-2017, 12:40 PM   #4 (permalink)
aerohead
expensive
Interesting stuff, does not look all that expensive to do, most likely just more stuff to go wrong when it gets older though.
I'm guessing most expense was developing the software and interface.
Maybe they can make a buck franchising the technology.
Fabricating the wing/pylon would be challenging.The 'outside' of each,would have to be fabricated over an 'inside',producing a properly ducted airway.Like investment casting,in which a lost wax insert is built over,then the wax is melted away,leaving a perfectly configured inside surface inside the structure.
BamZipPow (11-18-2017)
