Old 11-19-2017, 03:51 PM   #8 (permalink)
JulianEdgar
Thanks for the replies so far. As MetroMPG said, I am writing a book on home car aero modification. The book is quite large, and so I can use plenty of examples. It is being published by a UK publisher, but it will be distributed worldwide. At this stage it is looking like being 100,000 words and 350 pics.
As with any print publication, good quality pics are needed (ie typically at full res out of the camera, not at web resolution).
If you want to appear in the book, I'd suggest that you do the following:
1. Email me a couple of high res photos and a short description of what you've done, and how you tested the results. julianedgar1 at gmail.com
2. I'll get back to you to let you know if I am interested. (I hope I will be, but I might already have examples that cover the same ground, etc.)
3. I'll then ask you to write a more detailed description, or provide more pics, eg a step by step, or testing of different versions, etc
4. You will be mentioned by name in the book, as will EcoModder
If you have any questions, I am happy to answer them.
The Following 6 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (11-25-2017), BamZipPow (11-19-2017), Daox (11-19-2017), elhigh (11-29-2017), niky (02-07-2018), oldtamiyaphile (11-23-2017)
