Old 11-20-2017, 10:03 AM   #8 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.9 mpg (US)
The optimal shift points when accelerating are lower than what you get from the BSFC chart. That's because you are using fuel to spin up the engine, then throwing that kinetic energy away when shifting.
I use first gear just enough to get rolling, then immediately into second gear. If not in a hurry, I'll shift out of first as low as 1000 RPM. My technique is mash the gas pedal about halfway or a little more, then set the shift points to get the acceleration that I want. Typical shift points range from 1500 to 2500 RPM, and rarely as high as 3500 RPM pulling onto a highway uphill.
The Following User Says Thank You to JRMichler For This Useful Post:
Daschicken (04-25-2018)
