Old 11-30-2017, 07:48 AM   #3 (permalink)
Ecky
90 day: 40.51 mpg (US)
Originally Posted by Gasoline Fumes View Post
If it only idles high when moving, all you need to do is make the ECU think the car isn't moving.
Indeed, Natalya has a module for the Insight which can, on demand, feed the ECU a ~1mph signal, which could in theory allow for low idle while coasting. Our cars shut the engines off entirely in those cases though.
