Old 08-23-2008, 01:36 PM   #548 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Well I think I got my display all figured out. I found that if I disconnect the ground wire from the display, it will still run fine but it kills the backlight. It pulses just a little with the blinking light on the Arduino board but its not a big deal . So put the wire normally to pin 15 of the display to an NPN transistor that breaks the ground to the display. The different levels of brightness now work too.
I was kinda hoping I could kill the display entirely, but if I do that, it shows jibberish when it comes back on unless it is reset. So anyway, I think I got it working as intended. It does time out properly now and hopefully the killing of the backlight will make the screen less hot when not in use.
The display I used was from ebay, item# 320277596129. They say yellow-green backlight with black characters. It is actually a green backlight with blue characters, which still looks nice and is easy on the eyes. It looks just like the display on the old Casio graphing calculators.
Winter daily driver, parked most days right now
Summer daily driver
