Old 12-05-2017, 11:55 AM   #12 (permalink)
Fingie
Renault owner
Fingie's Avatar
Tegybi - '97 Renault Twingo 1.2 Mpi
90 day: 40.91 mpg (US)
aand it's running on the road.
thermostat changed and my buddy got the ignition electrics fixed. Also the horns and radio, some soldering must be done to the cluster so the lights will work and change sensor for water temp
already put 500km on it already and it seems to run well.
MPG will be calculated soon.
gearbox is a bit hard-shifted, but it's gotta hold until i get the 2.5TDI installed, then i'll get a M90 gearbox
Name:	T D I C C.jpg
If you don't make any mistakes in your life,
life itself will be a f*ckup.
it's not your fault, Renault
