Thread: Corovelo
Old 12-06-2017, 07:31 AM   #17 (permalink)
Ecky
90 day: 40.51 mpg (US)
Mine is 8T and is the latest gen, with composite gears and a temperature sensor. I cracked it open after a few hundred miles and the gears all still look good, but I'm probably going to run it at slightly lower power to protect clutch and gears. Geared hub motors feel a lot more torque-y at low RPM than direct drive, and tend to have better efficiency at lower speeds, so I probably don't need nearly as many watts anyway.
At first glance the Leafbike motor looked like any of the other eBay hub motors, but the efficiency graphs suggest otherwise. I might snag one to try.
