Old 12-09-2017, 12:59 AM   #10 (permalink)
redpoint5
I'm pretty much always running the heater in the Prius in the winter to keep the windows defogged. This runs 1 of the 2 cooling fans, which is usually sufficient to keep engine temperatures in the normal range even with a full grill block.
If I'm climbing a steep grade for many miles, the engine cooling fan might kick in with a full block. I'll open a strip up in the grill if I know I'll be operating at high load for an extended period of time.
