Old 12-12-2017, 06:15 AM   #2 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
You're trying to compare the fuel difference between steel and aluminum(alloy) wheels, is that correct?
If so, you can get aluminum wheels that weigh more than their steel counterparts, so you might actually be worse off running aluminum wheels. Lighter wheels will use less energy to accelerate and braking will take more energy to stop them. Cruising at the same speed and there won't be any notable fuel use difference.
And then there's the actual shape of the wheel/spokes and how it affects air flow. If they're acting as big fans, they're going to put more drag on the car than if they were smooth/flat and did not.
Its not as simple as saying aluminum (alloy) wheels give better MPGs than steel.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
mcrews (12-14-2017), Xist (12-12-2017)
