Old 12-19-2017, 06:34 AM   #5 (permalink)
retepsnikrep
OBDIIC&C Code and Manual Update
It's taken many long days of coding work to produce this new version and the updated pdf manual. Please got to Insight central to download the new versions.
OBDIIC&C Gauge - Insight Central: Honda Insight Forum
Lots I haven't tested. Have a look round.. The menu system is very different.
The top menu line is the active item.
So scroll Up/Down to get what you want onto the top line.
To exit the menu (at the moment) you have to be back to the first line with Menu at the top.
Then Press to exit.
Once you have your chosen item on the top line.
Right allows you to change that parameter value.
Left activates that function if it's a function.
Press restores the previous value back into the item shown.
So if you fiddle with a value and mess it up just Press to restore it.
For US cars you must use the Menu 'Car Type Flag' to select
UK1 1999-2004 = $01
US1 1999-2004 = $02
US2 2005-2006 = $04
Or the gauge won't work correctly.
Then you need to change the parameters for the appropriate defaults in the normal way.
There are now 16 default parameters for each type.
The sleeker code should make it easier for me to add the other DTC error database modules.
I saved about 5k bytes out of 50k in the rewrite...
I still have 13k space left in the pic18F2620 memory..
Bug and test feedback reports are vital to development.
Have a good xmas..
