Old 08-24-2008, 03:55 PM   #6 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Thanks for the tip dcb, unplugging all the injectors cleared the problem right up when identifying the right wire.
Even though I seem to have tapped the right wire now, I still can't get any fuel numbers to show up on the 'Guino. I even swapped the 'Guino from my car in there and it won't show any data...
So I know it's not the 'Guino, I know the "correct" wire is tapped (I continuity tested it going into the 'Guino just to make sure there's no problem with the wire)
Any other suggestions?
Any parameters I should be looking for that are required for the INJ input? (voltage, frequency, impedence)
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
