Old 12-23-2017, 02:35 PM   #9 (permalink)
D15r
D15r's Avatar
Civr - '95 Honda Civic Ri
tinkerbell - '90 Honda integra xsi
smokey - '00 honda civic gli
90 day: 43.36 mpg (US)
takaka - '00 toyota echo base with ac and ps
The top of the wingy-thingy is about right (~12°), the tumble-home of the sides is good.
I'd stretch a black mesh over the opening to make a perforated base plate. Easily undone for A-B-A testing.
So you mean close of the bottom, underneath the top surface of the spoiler, to prevent air exiting thereby causing a high pressure area that the air stream sees as similar to being a kamm back of 12 degrees?
