Old 08-24-2008, 04:37 PM   #170 (permalink)
whitevette
Water vapor?
Originally Posted by Bigs View Post
I have been researching on this a lot.
Water vapours, will it screw up your engine and exhaust system? I'm sending this guy an email concerning this to see his replies. I'll keep you posted!
Hi, "Bigs"!
I just caught your question about whether water vapor are messing up your engine / exhaust systems....Altho' I'm not the guy you sent the email to...I'd just like to say : Most water injection systems don't do squat; ie, produce much vapor. This is exactly the reason I went to the trouble / expense of developing a "new and novel" water vapor generating system.
Long story short : I finally was issued two US Patents on my concept ... and can tell you : No, the addition of more water vapor to the intake air will not affect your engine / exhaust system. The IC engine (ICE) already generates huge amounts of water vapor in the combustion of gasoline...so there is no problem. I was able to generate so much water vapor, the spark plugs shorted ( no spark) and the dyno engine just stopped running ( like the key had been turned off!). This was about 1:1 liquid gasoline to liquid water ( by volume). This is damp!! A true supersaturization of water vapor in the air.
Comments? -whitevette
[ chembustion at yahoo dot com ]
USA
