Old 12-27-2017, 06:56 PM   #670 (permalink)
changzuki
Changfa diesel + Suzuki
changzuki's Avatar
Centurion - '74 FIAT X1/9 Centurion Full Race DNA
Last 3: 143.5 mpg (US)
The electrical system on the original Centurion needs attention.
First on the list was a new ignition switch which is made exactly by Kubota as the original Centurion has. Easy peasy..
Second was a bit more challenging. No lights, etc.... So all the rocker switches were removed, disassembled, and contacts sanded with 1500 grit paper.
Now all the lights, etc, work. One of the strip lights added from the "Total Recall" movie still have a couple bulbs working.
Now that the dash lights work it's easy to see that the gauges are all foggy from the inside of the lenses and will need to be either disassembled and cleaned or replaced...
~CrazyJerry~
The Following User Says Thank You to changzuki For This Useful Post:
nemo (12-29-2017)
