Old 12-31-2017, 08:18 PM   #15 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Can't you get a 4WD oil sump (or eventually make a custom one) to overcome this clearance issue?
Such a small rig could be fun with a 4BT, but absolutely nose-heavy. Maybe that 3.3L engine that Cummins outsources from Komatsu could be a better fit, even though due to emission laws it would become nearly impossible to register your truck with a Cummins swap (unless you could get that R2.8 crate engine which is still too expensive).
2wd Vs 4x4
2wd/car =6.125" index 12.25" narrow block cross the lower bolts at crankshaft Centerline
4x4 =6.75" index 13.25" wide block(same as Mitsubishi diesel)
Results un the bolts over lapping . This requires in an adapter thicker than the stick out on the trans input shaft.(results in no pilot bearing support, a no go).
Emissions
If you put every soul in Montana in one place we wouldn't have enough people to pollute the air badly enough to need diesel smog requirements. . Solved.
Nose heavy
Cab set back to ficilitate a more proper 40/60% (fore /aft ) CG. Plus longer/better nose fineness raito.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
