Old 01-01-2018, 08:05 PM   #8 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Lbar View Post
I wish this Yukon had a manual trans, it probably isn't a difficult swap but I wouldn't consider something like that unless I was dealing with a trans failure.
If you ever swap a manual transmission into the rig, I'd recommend you to also consider replacing the pedal-activated parking brake for a lever-operated setup.
