Old 08-24-2008, 09:56 PM   #208 (permalink)
Johnny Mullet
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Originally Posted by Formula413 View Post
Do you monitor engine temp with the Scangauge? Most dashboard temp gauges will not show any variations in temperature once the engine is warmed up. You might be running hotter than normal and not even know it. That was the case when I covered the entire lower grill opening in my Escort.
Good you mentioned that. I used our shop scanner and monitored the temp PID before I started while engine was idling and after the fan cycled once and the temp was average around 190 degrees. After the block, I warmed it up again and waited for the fan to cycle once and my temp reading was the same.
You might not think there is any air getting in, but these 3 cylinder cars don't need much airflow. That gap between the hood and bumper seems to be more than enough for cooling purposes on this car.
