Old 01-20-2018, 12:46 PM   #11 (permalink)
AdrianD
AdrianD's Avatar
Originally Posted by nemo View Post
Thinking maybe a little less on the width maybe align it with the last groove of the tire. Just speculation on my part as most I see don't go to the edge of the tire. How far off the ground is the bottom? Don't forget about curb stops and driveway angles. Maybe others will chime in.
It's not yet on the edge, this is as big as I would go but I won't mind making it smaller. It's going to be strictly for highway use, only connected with 2 screws.
Originally Posted by DSMHondaGuy View Post
Maybe angle it back some to direct the air around the tire some, that would allow you to not need it to be so wide, reducing surface area.
Noted, I really like idea.
Thanks guys, I will update next week once I cut it from plastic
