I'd recommend going even higher on the tire pressure if you are comfortable with it. Many of us here use higher pressure and we find it improves handling response, wet traction, mileage, and decreases tire wear. The downside is that you have worse snow traction, but adjusting seasonally isn't a big deal.
You can get a
scangauge with ecomodder discount for $150. Details can be had
here. You might be able to get a used one off ebay or something for a bit cheaper, but they don't go for too much less.
As for the sig, you just have to take a look at this thread:
How to set up your mileage signature
Edit: Odd... the autolinker ususally automatically links when you type
scangauge or
mpguino... We'll have to look into that.
Edit2: Sure, NOW it works
