Old 01-26-2018, 02:37 PM   #1 (permalink)
fusion210
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
Free: Broken Scangauge II.
Buyer pays whatever actual expenses (paypal/shipping). Includes the unit/cable/original box/instructions/unused velcro strips.
I bought it in February of 2008 and used it until 2015 or so. At that point I'd just use it to check and clear codes.
The good? I think someone can fiddle with it and have something that works. The cable appears to be fine all the way up until the last inch, so if that's an issue it can be cut and crimped giving you an extra cable. But there is a lot of bad.
The top part on the front of the case is cracked in the middle.
The legs of that top part you screw the bottom section into are basically broken off and gone. It sort of still stays together.
I remember a few dead/stuck pixels in the display, you could still tell what you were monitoring.
The socket on the side stopped working, so I switch to the rear. That gave me issues later so I used a rubber band. This caused the socket to delaminate from the board.
As far as the cable goes, I could only find continuity between 5 of the 8-9 wires.
Free pickup near SE Charlotte.
I'll leave this up for a month but after that onto the landfill it goes.
I have perfect selling feedback on ebay and neons.org if that's any concern.
ID:	23406   Click image for larger version
ID:	23407   Click image for larger version
ID:	23408   Click image for larger version
ID:	23409   Click image for larger version
The Following User Says Thank You to fusion210 For This Useful Post:
MetroMPG (01-26-2018)
