Old 01-28-2018, 03:41 PM   #14 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
It might do a good pulse and glide then as well. They did say the 8 speed will now DFCO in all gears where before it would only in 1st and 2nd. It would be really cool if they could program the cruise control to do a simple 10 mph spread pulse and glide best using the engines peak efficiency to accelerate, and then cut fuel and use the Etorque to extend the glide. They also said it will help the 8 cylinder stay in 4 cylinder mode longer and more often. I had a 5.7 Hemi with deactivation and the slightest increase in throttle would drop it back into 8 cylinder mode. I ended up basically letting it lose a little speed to stay in 4 cylinder mode, then go with a moderate throttle to get back up to top speed. I think it did better than just running the cruise but not enough to put up with the trouble. If it would do it for you, that would be great.
