Old 01-29-2018, 10:21 PM   #301 (permalink)
BLSTIC
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
Originally Posted by Phoenix'97 View Post
Since I am using a somewhat restrictive air box with an equally restrictive paper air filter, the added airflow will be a benefit, so I am going to keep the ram-air hood functionality but it does need modification for the LS1 air box I am now using.
Do you have any measurements to support this (or have you seen any)?
I've seen the pressure drop measurements of a few intake systems now and while the entire system can vary from 4" H2O to 35", I haven't seen a filter represent more than 3". For reference 27.5" H2O = 1psi, an airflow meter typically represents around 10", and the maximum ram-air pressure you're likely to see is around 3" at 100km/h.
It's fairly easy and cheap to measure this kind of stuff. $10-80, depending on if you buy a guage or make one. I'm more than happy to point you at some articles explaining how and what to look for in an intake system.
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
