Old 01-30-2018, 01:15 PM   #9 (permalink)
ASV
weirdo
ASV's Avatar
thermal mas is better off inside the insulation wether your dealing with exes heat or insufficient heat. So put the insulation on the outside
R-Tech foam boards seem to hold up to weather well if not exposed to UV
and can be gotten with a reflective aluminum skin
