Old 08-25-2008, 08:22 PM   #7 (permalink)
kaveman12
EcoNoob
RSX - '03 RSX
90 day: 29.61 mpg (US)
Send a message via AIM to kaveman12
Originally Posted by ptsmith24 View Post
Edit: About maximizing tire pressure: Does that not decrease life of the tire? I keep mine at the recommended cold pressure on the inside of the door. I check the pressure weekly.
It may cause the center of the tire to wear a little faster than the edges, but the difference isn't huge. I keep mine averaged between the manufacturer's recommended (32 psi) and sidewall maximum (51 psi) as a compromise.
Edit2: I don't know about adding a block heater or blocking the front of the car. I live in south GA, so I think the time to warm up is negligible.
It stays pretty warm here also, so the need for that isn't much. I tried blocking my upper grille, but didn't like the temps I was seeing in summer. I may try it again in winter.
One final note: Welcome!
