Old 02-06-2018, 12:41 PM   #5 (permalink)
Angel And The Wolf
Or, maybe just a spring loaded second floor, without the end or side pieces. At slow speeds, where you would be enter driveways, the second floor would be held up against the real floor by the spring loaded hinges, but at higher speed, where reverse lift would be produced under the boat tail, the second floor is drawn down by the lower pressure, and keeps the lower pressure off the real floor.
Would this work?
Name:	2011 prius finished view With 2nd Floor.jpg
The Following User Says Thank You to Angel And The Wolf For This Useful Post:
BamZipPow (02-06-2018)
