Old 02-07-2018, 11:29 AM   #8 (permalink)
S Keith
Can't the hybrid system be disabled and the car driven normally?
The G1 Insight and HCH1 can be bypassed by turning the master off and unplugging certain connector(s) from the BCM/MCM; however, the HCH2 is a different beast. On both of my '06, I could bypass it simply by flipping the master switch off. I would get 12V charging between 1500 and 3500 rpm or so. I maintained confidence in the 12V state by running a voltmeter in the cigarette lighter port.
Others have reported this DOESN'T work for them on other years, and their 12V is run flat. I know of no other way to bypass it on an HCH2.
The concern with bypass is retaining 12V charging. It's worth experimenting. One could also mount an alternator. I think somebody did it on this forum or over at Greenhybrid. It wasn't pretty, but it worked.
