Old 02-10-2018, 01:31 PM   #18 (permalink)
aerohead
wing
Originally Posted by Angel And The Wolf View Post
Maybe I'm looking at it wrongly. Instead of trying to holds the rear up, maybe I should put a wing in front of the grill to push the front down.
The wing will ruin the flow.Hucho would consider the factory nose already 'ideal.'
I would recommend that you put your effort into cleaning up the belly and rear wheel openings to guarantee quality flow to the boat tail.Then see if you can figure out how to get the 'final' diffuser angle as close to 2.8-degrees as you can.
If the bottom of the tail is steep,it will create high-drag,attached,counter-rotating longitudinal vortices below the tail; and probably enough turbulence to cause flutter.
