Old 08-26-2008, 06:08 AM   #33 (permalink)
Multiades
Protege - '94 Protege LX
90 day: 28.86 mpg (US)
Originally Posted by cfg83 View Post
My DOHC has a different BSFC map than the SOHC :
http://ecomodder.com/forum/15008-post4.html - Post #4
I don't have the BSFC map for the SOHC. I should find it. However, even if I did find it, I wouldn't know how to interpret the differences, .
My current tires are one-size-up from stock :
My Continental Contact-Pro Tires
It would be pretty hard to find the optimum speed to drive at for highway mileage, but assuming you were able to reduce Cd on your car enough that aero drag was less of an issue, I bet putting it near the center of the sweet spot on that BSFC graph would be about right.
55-65% Load (perhaps 18in/Hg vacuum) at 2500rpm might be ideal.
With your actual tires, speeds should be as follows:
Code:
RPM		MP2	MP3
2000		58	48
2100		61	51
2200		64	53
2300		67	56
2400		70	58
2500		73	61
2600		76	63
2700		79	65
2800		82	68
2900		85	70
3000		88	73
I somehow doubt you can do 73mph efficiently in a car that isn't shaped like a needle -- looks like the MP3 gear might be better in some ways for that. The BSFC "sweet spot" seems to extend down to 2000 with room to spare, so maybe your best mileage will be at 60ish.
If the car feels absolutely powerless on flat highway at 2k that's probably too low. Aero would help.
50mph is probably too slow though.
In terms of safety, under an emergency, I would have to downshift to a lower gear no matter which 5th gear I have, so I don't consider it to be a critical issue.
What, in case you have to go really fast because your wife is in labor?
-Chris
