Thread: Tesla Model 3
Old 02-14-2018, 03:12 PM   #285 (permalink)
samwichse
Thalmaturge
The Tinyvan - '07 Honda Fit Sport
You just have ubb tags before/after your whole table like code and /code but with brackets around them (just like the quote tag) that give you a monospace font and spaces and tabs are maintained.
Then you can do what i did there and paste data straight from Excel/LibreOffice and it will come out as a table. Likewise copying a web table should go right in as a table too.
Code:
Vehicle	Tesla	Chevy Bolt	Nissan Leaf
Capacity	85 kWh	60 kWh	40 kWh
HP hours	3,740	2,640	1,760
Weight	1,200	959	560
Lbs HP Hr	10.52	11.92	11.06
HP hr/lb	3.125	2.75	3.14
Range	265	239	150
HP hr/mi	14.11	11.04	11.73
Cost per mi	4.36 	3.34	3.35
The only problem you'll run into is if a column has values that exceed the tab stop, data will run into the next column and things will get shuffled, as above.
